1 - 6 of 6 Posts
I am getting ready to install a 6" Skyjacker lift into my 85 W350... Since my drag link is already worn, I figure that this would be a good time to go to crossover steering too... I would like to stick with TRE for easy parts availability...
I am wondering what steering arms (if any) I should steer away from (no pun intended)... I see quite a few on E-Bay, most of them do not have the angle milled for the TRE, and most of them do not have the holes drilled for the "cone" washers... both of which I am guessing are "required" for my application (please correct me if I am wrong).
The ones I have found that seem to be "correct" are:
Sky Manufacturing - http://www.sky-manufacturing.com/new/detaproduct.php?id=101
JKW - http://jkwoffroad.com/offroadproducts.php
Off Road Design - http://www.offroaddesign.com/catalog/Dana60crossover.htm
Blue Torch Fab - http://bluetorchfab.com/store/product_info.php?cPath=66_29_32&products_id=232
Ballistic Fab - http://www.ballisticfabrication.com/D60-high-steer-kit-for-kingpin-axles_p_1246.html
is any one preferred over the others? Are there any other manufacturer(s) I should look at??
Discussion Starter · #2 ·
I personally run ORD, but would consider Sky Manu for the less $$$$ of basically the same kit.
Big supporter of WFO Concepts now, and am converting to their highsteer setup.
1 - 6 of 6 Posts
