1 - 15 of 15 Posts
Anyone have info on the current conditions?
Dreamflows shows little/no flow but curious on snow or other factors
Was up there a week ago and no one had made it past the off camber section about 1 mile past driveline because of the amount of snow.
Discussion Starter #6
Any 'guesstimates' on flow rates at the 1st crossing or committee?
Morning and evening? As the flow changes thru the day
Is committee open for exit?
TJ 5"lift on 35's
Discussion Starter #8
Dreamflows only shows outlet at the dam, not the added run off which is the big factor now
My little jeep gets pushed around in the flow =/
Report I got yesterday was that folks went in thru Eagle Lakes and made it to Committee and then went back out the same way. The road out thru Committee is likely still drifted in places, but a buddy of mine is heading up there this weekend was was going to check on going out Committee after getting up to Meadow.
Gate to Rattlesnake was open so I'd imagine it's fine, might be some drifts up top as Signal looked like it still had snow.
Spent the weekend camped out on Rattlesnake (Road 85) out of Cisco. We couldn't get to Sterling, Fordyce, or Signal Peak in the RZR's. Several folks in tube buggies on 42's or larger turned around also. The sidehill snow drifts were nasty.
1 - 15 of 15 Posts
