SOLD - Currie Rock Jock II
3K views 11 replies 6 participants last post by  1972Blazer
#1 ·
$3000.00 or best offer
Currie Rock Jock II - USA Manufactured Ductile Iron Center Section, 60.5" WMS, 5x5.5 Bolt Pattern, Rock Bridge for four Linking/Trussing, AR400 Heat Treated Skid Plate, HD Aluminum Cover, 40 Spline Competition Chromoly Axles, 5.13 Gears, Spooled Locker, Large 45mm HD Bearings, Wilwood 12.5" 4 Piston Disc brakes W/ E-Brake, 1350 Yoke
#5 ·
Am I seeing things? Is the pinion centered or is it slightly off center to the drivers side?
At 60.5 width it’s the width of a Jeep TJ axle but what was it built for?
Thanks
It does look offset closer to the driver side. Too bad if that's true because it would be perfect for my 94 Explorer if it was offset the other way.
The pinion is offset 1 inch to the drivers side. It was built to spec for a TJ without any brackets.
You have insufficient privileges to reply here.
