1 - 12 of 12 Posts
I'm not sold on those things. Most people have a problem with the way the ball mount rattles, which is a up and down movement. That doesn't do anything for that. And if you have forward/back slop, then you have issues that need to be fixed. You can do a simple anti-rattle device, which is a lot cheaper. The only advantage that I see to that set-up in the picture is if it was for a pintle hitch. But even then, you are still going to hear the pintle ring bang around.
I forgot about those, someone is making a "Hitchshim" or something.
Just run a bead of weld on the hitch, grind to fit, no more slop.
I aways thought they were to cushion the schock from starting and stoping????????? not noise control.
My BIL has a big cushioned bumper on his pickup he used farming but it takes up the spare tire mount area.
IMHO, they would do absolutely NOTHING. The internal friction for all the weight on the reciever would keep it from slidely back and fourth anyways..
not only that, but a hollow tube, with the sides cut out of it can't be even remotely as strong as a 2" solid receiver, like most properaly rated ballhouts are.
FWIW the pic in the first post is a cutaway to show the Polyurethane Cushions.
Has anyone used one?
I had one years ago on a 1/2 ton Chevy I had. I would tow 5-6K with it now and then. It bent the pin in the housing cause the shear points are too far apart. It ended up going with the pickup when I traded it, cause I couldn't get it back out. IMO it didn't help out.
Our one ton on the farm had a hitch with the same principles, but used 4 heavy springs. It wasn't a receiver hitch, it slid on two large rods, each one had a spring on each side. It had a 1" plate the ball bolted through. It was a very heavy duty hitch, and helped immensely with the constant push-pull from our water trailer. Then again, that trailer was over 20,000 lbs, too. All in all, it worked great, even on smaller trailers.
Discussion Starter · #10 ·
That sounds just like my BIL's setup.
Probably a DMI, I have one on my truck.
1 - 12 of 12 Posts
