1 - 20 of 21 Posts
I build a custom width high pinion dana 44 for my XJ and have had quit afew enquiries. So I put this build and tech page together. I hope this helps others that plan on going down this road. I will continue to add on to the post as I have time to type it up. The build is done and works well.
In the late 1960’s Ford directed Dana to design a high pinion, reverse spiral 44. The first 3-4 years of production used a kingpin knuckle design that is obsolete, and difficult to play with. One could use an early housing and press aftermarket inner-knuckles on to fix this limitation. About 1970, Ford began utilizing a ball joint inner knuckle that is very common. The early to mid 70’s F-100 and F-150 Ford axles utilized drum brakes, and either a 5 bolt or 6 bolt spindle pattern.. This should not be confused with wheel bolt pattern. The spindle bolt pattern attaches the spindle to the outer knuckle. All F-100’s and F-150’s were a 5 on 5.5” wheel bolt pattern and they are about 67” wide, WMS to WMS. These early Ford units are desirable because Ford welded the suspension mounts (Radius Arm “C’s” as they are commonly known) to the axle tubes. Beginning in mid-to-late 1976, Ford began casting the suspension mounts as part of the inner knuckle assembly. These mounts take up a considerable amount of tube, and if you want to use any other than Ford’s suspension design, they will vex your efforts. In 77-79, the vaunted an highly prized “Camper Special” F-150 was available. This is basically an F-250 axle with 5 on 5.5” outers which you are going to ditch anyway (more later). Don’t pay a premium for this unit unless you have the odd desire to run leaf springs, as the extra material in the leaf spring perch makes it difficult to mount link mounts. The same applies for the F-250’s of that vintage. In late 1979, Ford revamped there whole front suspension design, and introduced the highly undesirable, Twin Traction design.
With this information in hand I set out to look for a 1970 to early 1976 Ford F-100 or F-150 High Pinion (Reverse Spiral Cut) Dana 44. I came across a early 1976 F-150 axle that I purchase for $175.00.
I decided on those years because Ford welded the suspension mounts onto the axle and I had plans on shortening the axle to a waggy width (more on that later). I also want to run 5 x 5.5" wheel pattern.
I tore the axle down to the bare housing to get a good look at what I was up against.
I soon realized that the highly charished 1976 Ford F-150 axle with disc brake, was not going to be the cost savings I had planned on. The hubs, rotors, and hub lockouts were not salvagable. This is why you can use a 1970 to 1975 F-150 drum brake axle. You will most likely discard everything from the balljoints out.
I then cut the suspension mounts for the radius arms of the axle. This step was fairly easy. Just take cation not to cut to deep as to cut into the axle tubes.
I then took the time to grind the remaining welds off the the axle tubes and took a wire brush to the axle to clean it up. Take your time on this step it will make the build cleaner and nicer to work on.
At this point I contacted Bob and Matt from TNT Customs about making a truss for a High Pinion 44. I have used the skills of Matt and Bob many times in the past. Being one of the first to run their Dana 30 Truss I know there attention to detail and quality was second to none.
http://www.tntcustoms.com/webV4/truss_d30.asp
After a few long talks with Matt and Bob about narrowing the axle to a Jeep Wagoneer width so I could use Wagoneer axles we came to the conclusion that to get the pinion inline with the front output shaft of the transfercase we would have to narrow the axle equally on both sides. This would cause me to purchase custom length axles instead of using stack axles out of a Wagoneer. Because I was planning on purchasing Chromoly Axle Shafts this was not much of a problem.
I did some research and came up with these measurements comparing the different years of High Pinion Ford Dana 44's and Jeep Wagoneer Axles.
1978-1979 BRONCO (Length 18.91 in.; 30 Spline;Driver Side; ) 39143
1978-1979 BRONCO (Length 33.91 in.; 30 Spline;Passenger Side; ) 39144
1972-1977 BRONCO (Length 18.31 in.; 30 Spline;Driver Side; ) 38809
1972-1977 BRONCO (Length 27.94 in.; 30 Spline;Passenger Side; ) 38810
1968-1979 F-100 PICKUP (Length 18.91 in.; 30 Spline;Driver Side; ) 39143
1968-1979 F-100 PICKUP (Length 33.91 in.; 30 Spline;Passenger Side; ) 39144
1975-1979 F-150 PICKUP (Length 18.91 in.; 30 Spline;Driver Side; ) 39143
1975-1979 F-150 PICKUP (Length 33.91 in.; 30 Spline;Passenger Side; ) 39144
1980-1984 WAGONEER (Length 15.8 in.; 30 Spline;Passenger Side; ) 39459
1980-1984 WAGONEER (Length 32.12 in.; 30 Spline;Driver Side; ) 39461
1974-1979 WAGONEER Disc/Drum;Drum/Drum (Length 33.19 in.; 30 Spline;Driver Side; ) 39339
1974-1979 WAGONEER Disc/Drum;Drum/Drum (Length 14.69 in.; 30 Spline;Passenger Side; ) 38808
Using the measurements for the 1975 to 1979 Ford F-150:
18.91" on the Drivers Side
33.91 on the Passenger Side
And the measurements for the 1980 to 1984 Jeep Wagoneer:
15.8" on the Drivers Side
32.12" on the Passenger Side
I originally was going to shorten the axle to a Wagoneer width which would make you shorten the drivers side 3.11" (18.91"-15.8"=3.11")
and shorten the passenger side 1.79" (33.91"-32.12"=1.79")
But with the decision of shortening the axle equally on both sides to keep the Pinion where it should be it came out that I should shorten the axle on both sides 2.45"
3.11"+1.79"=4.9"
4.9"/2=2.45"
NOTE: If you decided to to narrow the axle to a Wagoneer width you would only be 0.66" off of center. The problem you run into narrowing your axle to a Wagoneer width, and keeping the coils center, is that the drivers side coil bucket will end up into the cast portion of the center section where the drivers side axle tube is installed. I truely believe that you can run 0.66" off center without ill effects.
To mark the correct spot where I was suppose to cut the axle, I took a few measurements. I needed to know how far out the inner knuckles sat out from the end of the tube. With my dial calipers I got a measurement of 0.130". So I added that to the 2.45" and mark the axle tube at 2.58" from the outboard side of the inner knuckle. I then cut the inner knuckles off with a sawsall just inside the welds on the axle tube. This gave me clearance to use a chop saw to cut the axle tubes to the right length. If using this method make sure that you set up the chop saw level and that the axle tube is also level so you achieve a perfect perpendicular cut.
You will have to remove the remaining portion of the axle that is still left in the inner C's. To do this you will need to remove the weld portion on the inboard side of the inner C's. The most efficient way to do this is to clamp the inner C into a vise and grind the weld down till you are flat with back surface of the inner C. At that point you will want to grind in a cone shape removing mainly the portion of the axle that is still in the inner C. You will soon see a circular line appear. This tells you that the axle portion that is still in the inner C is ready to be pressed out or knocked out with the proper size drift and a hammer.
Once you have the inner C's cleaned up, and the axle cut down to the width desired, you are ready to install them back on the axle. First you will need to now what your Pinion angle will need to be. I took the measurement off the Dana 30 that was installed in my Cherokee to get a base line. To get this measurement you will need some type of angle finder. I have two types, a dial type angle finder and a digital angle finder. Both work extremly well.
The best way I have found to get the most accurate pinion axle is to take it from the differential cover mounting surface when the differential cover is off or the flat portion next to the differential cover where you would install a case spreader.
Note: This picture is not of my axle and used for reference only.
I came up with a measurement of 13.5 degrees on my Dana 30 with my Cherokee lifted 9 inches. Due to the added higth of the Dana 44 subtract 0.5 of a degree to come up with a desirable pinion angle.
Here is a rough estimate of what your pinion angle should be with a desired amount of lift:
NOTE: All these estimates are based on using a Jeep Cherokee and should be checked.
6 inch lift = @10 degrees
8 inch lift = @12 degrees
9 inch lift = @13 degrees
With your pinion angle figured out you will need to level the axle. I used jack stands and cardboard to achieve this. Once you are level support the pinion yoke to the desired pinion angle.
It is time to set your caster angle on your inner C's. Ideal handling comes from about 4-7 degrees of castor. I’m very happy with 5 degrees. With the axle on a stand, you can measure the caster by putting an angle finder on the bottom flat of the inner knuckle where the ball joint presses in.
Set the inner C against the end of the tube, rotate it to the desired Castor angle and make a reference mark across the inner C to the axle tube. Set the inner C aside and use a square to mark reference line down the axle tube. This will give you a guide to keep your inner C at the proper Castor Angle will driving on the inner C. Just keep the mark that is on the inner C aligned with the mark down the axle tube. Remember not to drive the inner C to far on. You must stop at the previous measured point at which the inner C stuck out past the end of the axle tube. In this case it was 0.130".
You will need to repeat this process to both sides. Try to be a precise as possible. Your castor can ussually be off from side to side by .5 degrees without any effects to your driving characteristics. If you are off more than .5 degrees you should remove the side that is farthest from your desired castor angle by driving it off and repeat the install process.
Once the inner C's are installed back on the axle tube. Weld them into place.
Discussion Starter #2
This is not my axle. Picture was used to show progress.
At this point I contacted Matt at TNT Customs about the High Pinion Dana 44 Conversion we spoke about earlier. I was told the kit was built and was ready to go into production. Bob at the shop in Wyoming had installed their first kit on a High Pinion 44 for a TJ and it fit perfectly. Matt cut the parts and I had them in no time. I took the kit and home and dry fit it to the axle and it was a perfect fit. Here is a link to TNT Customs High Pinion Dana 44 Conversion:
http://www.tntcustoms.com/webv5/Dana44Swap.asp
With parts in hand it was time to install all the bracketry that came with the conversion.
1. Truss with upper control mounts
2. Left Spring Bucket
3. Right Spring Bucket
4. Left Lower Control Mount
5. Right Lower Control Mount
6. Two Super Flex Bushing Kits
INSTALL STEPS:
1. Reset your desired pinion angle again and make sure your axle is level to the ground.
2. Place Truss onto axle. It will automatically center itself over the center section.
3. Rotate the Truss till the top of the Truss is level. (Depending on your pinion angle, you may have to trim the backside of the truss where it goes over the center section. Be careful not to trim anymore than necessary.)
4. Butt the Coil Buckets up against the edges of the Truss and level them. (Make sure you have the coil buckets on the correct sides.) Depending on what type of shocks you run you may want to concider step 4a. before welding on the Coil Buckets.
4a. If you are planning on running a standard type of shock with a bushing on the lower end, you may want to concider this type of mounting system for your shocks. I went to the hardware store and purchased two 5/8th's inch bolts approximately 6" long. I cut the heads off the bolts so they were like a threaded pin. I then flipped the coil buckets over and set the bolt onto the outboard side against the flanged portion of the coil bucket with 1 3/8" of the non threaded portion show and welded the bolt to the coil bucket. The reason for the 1 3/8" non threaded portion is to prevent you from overtightening the lower bushing on your shock during install.
Repeat this process for both sides
NOTE: Make sure you weld the bolt to the outboard side or there will not be adequate clearance for the shock.
5. Once you have the Coil Buckets against the Truss and level then you will tack them to the axle.
6. Remove the Truss and fully weld the coil buckets to the axle.
7. Place the Truss back onto the axle and level it.
8. Weld the Truss to the axle. CAUTION: This Truss was not designed to be welded to the center section. There is plenty of strength with the amount of weld surface you will have. Also you will want to move around when welding the Truss to the axle to prevent any possible chance of warping the tubes. If you have the capabilities to stand the axle vertically after you are done welding do it. I strongly recommend it. It will help the heat disepate up out the end of the axle tube. Remember heat rises and if you leave the axle sitting horizontally the heat is trapped and the axle tubes will not cool evenly.
9. Once the axle has cooled level the axle again and reset your pinon angle.
10. It is now time to mount your lower control arm brackets. You will take the lower control arm bracket and check to make sure it is the correct side. You can tell because when you hold the bracket against the axle tube it will angle inwards. If it angles outward it belongs on the opposite side of the axle. Once you have figured out which lower control arm mount is which side take it and align the inboard side of the lower control arm mount up with the inboard side of the coil bucket. You will then rotate the lower control arm mount till the top (or flat portion) is level or parrallel with the coil bucket. Then tack the lower control arm bracket in place.
11. Repeat step 10 for the opposite side.
12. After the the Lower Control Arm Brackets are tacked into place double check their location and weld them on.
NERD
Kick ass write up! This needs to be added to the FAQ!
Good job man. I especially like this part from T&T:
We strongly recommend that, if modifications are necessary, our customers measure three times, have a friend measure twice, agree on what's to be done before it's done, and finally making the mod only after sleeping on it for no less than 8 hours.
Here is my list. (just Dana 44 front axles 67-2005)
after the cost of the axle plus bearings, ball joints, rotors, calipers and all the miscellaneous bs need to get a nice axle, the bracketry and truss set-up at about $820 plus shipping and tax, doesnt this run you into dana 60 territory?
awesome write-up, by the way.......
add that $820 to the $1200 you'll pay for a junk yard 60 and the 44 still looks like an ok deal. i know after i bought brakes, gears, locker, and lockouts i was into my 44 for about $900 ( empty housing was free) i was thinking that i screwed up but if i got a 60, it would still need all the same stuff and id be into it a lot more. i still wish i would've went with a 60 but money gets tight and you run with what you can.
Wouldn't it be better to take the caster angle from the axle under it's stock location (or off the spring perches) rather then based off your previous axle's caster that was adjusted for lift? Just kinda curius as to your reasons behind adjusting the caster like that.
My XJ is going to be riding on about 7-8" of lift when it's done, but I was going to set my caster to the stock angles.
Discussion Starter #9
Stock Caster Angle on an XJ is 7-8 degrees. I did alot of research and found that anywhere between 4-7 degrees worked well with larger tires. I run 35" Krawlers and decided that 5 degrees would be the optimal caster angle. With bigger tires and to much caster angle like 8 degrees it has a tendency to make the steering snap back harder than I would like when coming out of a turn. Plus I was told it increases the amount of effort to turn the wheels. From the research I found that 5-6 degrees castor worked the best and thats what I went with. It drives so much better than the previous axle that did not have the caster adjusted for the pinion angle. It had a tendency to wander down the road.
youll end up with a badass 44 and i guess its not too bad with a free housing. i paid 175 for my front hp 44 and havent really gotten into the incidentals yet, still working on having the sleeves done. im hoping for around 500 set-up minus whatever locker i choose, hell i might just spool it.......
I have made a few of those for TJ's and XJ's. I target the 77-79 3/4 ton set up for leaf springs and use waggy inners for wms-wms of 61 1/2. Makes for real nice drive shaft angles!
For those reading along, if you want the facts and the correct years for the above see my web page, in sig.
Not a bad write up, but your facts should've been researched more.
Discussion Starter #14
At no point did I ever think I was an expert. I have referenced your page a few time and got some good info. I do see how you seem to want to be the number 1 King Dana 44 guy by your comments. You can have that title for yourself. I just thought it would be nice to write something up to give others the chance to see another possible way to build a HP44 for their Jeep without having to fabricate all of their own stuff. Yes I have a list of axleshaft lengths since the beginning of man kind but thought that I would post the ones I thought was need for my build.
So heres to you mister Dana 44 knowledge guy:beer: :beer: :beer: :beer: This Buds for you
awesome. I saw the sticky on Jeepin.com
and Mr.N do you have a list like that, but with spring pad widths?
I run 5 degrees of caster on my Xj front and it steers great with the 36"s and 8" lift. Usually you want to run slightly less then stock caster numbers when you have the larger tires, thus 5 usually works great.
As for the 44 fronts from Ford, the 78/79 HP44 is the one to go for, 1/2" tubes and no cast in radius arm mounts.
Nice writeup tho man, took some time to do it i see.
Just finished a major portion of a similar project, but ARB and TnT's track bar mount:
Cruzin Illusion
Not trying to call you out or anything but... are you CRASH from NAXJA?
Because most (about 80%) of your write up is a copy and paste of his...
1 - 20 of 21 Posts
