1 - 20 of 50 Posts
Are you going to put the rear box back on it afterwards?
what are you using to add to the Frame, and where are you gonna cut the frame?
Are you getting longer to add a dual case setup or just to add some stability to it?
keep the pics and description comming, I wanna see how this pans out for you. :D
HEY ITS THE ZUK FROM THE POST 35'S ON A SAMURAI WITH THE HUGE BODY LIFT.... GET RID OF THE BODY LIFT IN THE PROCESS OF STRETCHING (GHETTO) IS OUT THESE DAYS
KEEP THE PICS COMING:D :flipoff2:
sorry guyes the body lift stays im not cuting ther fenders out to clear the tires.. tubes will be soon the frame first.the box will be going back on.and 2x4 tubeing will be what the frame is streached with.oh and by the way it only hasa 3"body lift...it is getting longer to get all the goodies back under the hood.
Discussion Starter · #9 ·
its a 2.8 ford with a 4.3 ford van radiator held on with zipties at the moment....mow its back under the hood but i havent mounted the new radiator yet...
you are going to put the tub back on? I'm just trying to figure your rationale on the cut and splice times 2 you are doing. What are you doing about the outward bend of the frame in the section where you cut? it looks like you cut out the gusseted piece of frame where it starts its outward bend, reasoning for the gusset.
I just cut mine at the rear frame crossmember. Buttweld ext, then gusset them. I can't see doing two buttwelds and the gusseting them both. I am trying to extend the frame without it looking like frame extensions....
Discussion Starter · #14 ·
i didnt cut any gussets but i wanted it cut in front to give me more room under the body. with the extra room im recessing a tool box under the floor.if it was cut at the end i wouldnt be able to get my box in it.you know all that stuff that takes up room in the back and makes the back seat crouded,will all be under the floor now.sounds kinda strange but you got to bear with me and youll see....
Discussion Starter · #17 ·
yeah i made some but i got embarrased at what i did so those pics arnt here.when i welded the new spring hangers on the axil shifted on me and is to far backso i have to cut it out and redo it.ill get more done this weekend to show youall.as for the pics i post through montypics.com thanks guys for the intrest and illl keep you all posted
HOLY CRAP YOUR CAMERA TAKES PICTURES OF THE FUTURE..AUG-3-2003 WHERE CAN I GET ONE OF THOSE
sweet just had to give ya some s#it since i am the only one who caught it on the board i was feeling kinda special
:flipoff2:
oh yea the body lift looks bigger since the glass pack hangs down thats what messed me up before it looked like a 5"er
1 - 20 of 50 Posts
