zukzilla4x4 said:
thats a good one for shure.but if you look at the shadows on it there the same on both doors dead give away.heres another
Hey, that's my quick and dirty chop.
In the picture of the black one you will see that the landscape in both door windows is identical except for the tower has been removed in one.
Also, the foreground clump of grass under the door and the gravel underneath each door is too regular/repeating.
Blur/dodge tool has been used for the clouds over the doors.
Plus a bunch of other stuff...
I'm not sure how practical that second set of doors will be. On one hand it is a pretty narrow opening - might only be good for kidlets. On the other with the way the door hinges work on a Sam you can really swing that puppy out of the way with a longer door strap and it can't be any worse than the production 3 door style pickup truck cabs that are out there.
Went out with the tape measure a few months ago to measure/appriximate the different panels munged together. The 4 door with a SWB rear tub would fit within the same length as a factory LWB. So in theory it is no worse than a factory LWB for proportion visually.
Still can't make up my mind if it looks goofy or not though...
[email protected]
