1 - 20 of 117 Posts
well ive seen a 3/4 ton zooki but a 1 ton zooki?
Welcome to POR.:D
:flipoff2: :flipoff2: Newbie:flipoff2: :flipoff2:
I guess you haven't seen the 2.5 ton Samurai either.:flipoff2:
:eek: :eek: :eek: BADASS!!
You know....cough.... if you ever need a zuki to work on....err...i would let you put a 14 bolt....cough... in my zuk... you know, just in case you run out of things to do..... :D .. i live in colorado springs colorado at 5..........!
Awesome man. keep the pics coming.
:flipoff2: :D :flipoff2:
Jon
Pssst. Krawwler,
Throw that volt guage away and replace it with an amp guage. The volt guage, unless you pay real close attention to it, will only tell you that your battery is about to go flat. An amp guage will tell you if you are charging, or discharging your battery. Your rig could be running perfectly normally, but with a bad altenator(sp?), and a volt guage, chances are you won't notice it until it's too late. An amp meter will show you that you are running off of the battery as soon as it happens.
I know, a volt guage is easier to hook up, but the amp guage is worth the trouble.
1 - 20 of 117 Posts
