1 - 15 of 15 Posts
I'm dissassembling my front dana 60 and I have removed the inner tube seals, but I think there is still a guide in there
how do i get this out?
[ 10-30-2001: Message edited by: fcfred ]
Fred,
what kind of "guide" are you referring to?
I popped the seals outta my 60 inners with
an old axle shaft. (I didn't plan on reusing them) and after they were out, there wasn't
anything left inside the tube.....
--Sherpa
I dot believe you will ever get them out the area you are refering to is machied to accept the axle seal its the tube your looking at <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0">
Originally posted by fcfred:
<STRONG>the seals look like a piece of rubber attached to a round piece of sheet metal
the guide looks like a thick metal ring
i'll try to get some pics</STRONG>
Fred there are two different types of inner seals at the carrier.There is the older type that looks like a piece of rubber with a bellish shaped ring that protrudes outward toward the knuckle aspect of the tube like what you described. The newer version is a straight seal like the wheel bearing seal on the back of the bearing hub.If you have the older style the seal often rips away from the bell shpaed part taht you described..You can try taking a long piece of pipe and knocking it out..Another option is try driving something between it and the housing so it will dislodge..if you need any further help pm me..
this is what I removed
<IMG width=270 height=203 SRC="http://www.pirate4x4.com/ubb/uploads/inner tube seals a.jpg">
this is what is left
<IMG width=324 height=243 SRC="http://www.pirate4x4.com/ubb/uploads/DRIVERS SIDE INNER TUBE copy.JPG">
fred the weird black stuff is silicon the factory used to seal the tubes to ensure that they didnt leak
I normally do not do "ya I agree" posts, but figured a second opinion on this would put your mind at ease. You have removed the seal, in the pic you posted, there is nothing in the tube/housing but the machined bore and the sealant used at the OEM to prevent leakage
I thought that stuff was part of another seal
because it looked too perfectly rounded
compared to the silicone seals I'm used to
applying. FYI Fred, don't go to Napa for your
rebuild kit. All they have is balljoint
stuff <IMG SRC="smilies/puke.gif" border="0"> <IMG SRC="smilies/mad.gif" border="0"> BTDT
1 - 15 of 15 Posts
