1 - 10 of 10 Posts
Moderhater
ok i REALLY think there should be a WANTED! for the vendors, but whatever :shaking::shaking:
i need some 1 inch bored 1 inch thick (preferred) weld on d ring mounts. like the ones PSC sells. ill buy them from them, but would rather support a board vendor.
i got some from PORC, and all they were were 1 inch thick by 2 inch wide strap with a hole drilled in them. :rolleyes: less than appealing.
Something like this?
Disclaimer: its 2" wide peices cut from 1" plate and the holes drilled and the ends milled round.
Moderhater
yea, but yours took longer than 5 minutes to cut out, unlike the ones i got from PORC. they were litterally a peice of strap like that, just band sawed and drilled for 20 some odd apeice. i guess the ones from poisen spyders isnt too bad in price then, being 30 each, triangled, drilled and chamfered for welding....
basically i want a vendor to gimmie some of these :grinpimp:
like i said i have no problems buying from them, but want to support a vendor.
same here. 8 bucks, no gathering steel, fabing/cuting them out, drilling/machining the center hole. It's like a sore peter, you can't beat it.
Hillbilly
1 - 10 of 10 Posts
