1 - 7 of 7 Posts
I am trying to talk myself into saving up for some coilovers. Does anyone know anything about these doetsch techs? it looks like 15" travel emulsion shock(like the pic) can be setup dual-rate for about 300$ a corner. Anyone know how well they work?
pic came from rock logic
www.rocklogic4x4.com
-greg
Travis,
Any problem with the coils hitting the frame or any binding problems. That's not normal to bend shafts and blow seals a lot unless the shock is getting side loaded. Just curious what the problem might have been.
tony k
· Premium Member
i just gave my set of doestechs away. they are ok if you don't plan on running them very hard. i bent several shafts and blew at least one seal every trip. i replaced them with sway a ways
· Premium Member
I'M WITH ROCKCRAWL I HAD A SET AND THE FIRST TIME OUT THE SEALS BLEW OUT. THEN LATER THAT SAME DAY I BENT ONE IT HAD TONS OF CLEARENCE AROUND THEM AND WAS ON A LIGHT RIG MY OPINION IS THERE JUNK :p
1 - 7 of 7 Posts
