1 - 20 of 113 Posts
This is where all the information you have about the Dana 18 transfer case found in early Willys vehicles goes.....
I will try and keep the 1st post updated with new links from the thread as it hopefully builds into a good reference on history, rebuild info, parts sources, parts reviews, issues, fixes, and modifications.....
General Info and History....
http://www.novak-adapt.com/knowledge/model_18.htm
http://www.advanceadapters.com/tech-vault/dana-18/
Rebuild information....
Good write-up with good pictures by jalbrecht42
http://www.pirate4x4.com/forum/showthread.php?t=690670&page=6
Willystech rebuild.
http://www.willystech.com/wt/Model18TCase/Model18TransferCase.html
This old jeep rebuild. Great quality.
http://thisoldjeep.21.forumer.com/viewtopic.php?t=248
Rebuild with 3.15 Teralow gearset.
http://www.jeepsunlimited.com/mambo2/index.php?option=com_content&task=view&id=43&Itemid=30
Parts....
http://www.novak-adapt.com/catalog/dana_18_parts.htm
Overdrive information and parts
http://www.hermtheoverdriveguy.com/id21.htm
Issues....
Popping out of gear and bearing failure.
http://www.pirate4x4.com/forum/showthread.php?t=985554
Sealing issues.
http://www.pirate4x4.com/forum/showthread.php?t=987443
Gear noise.
http://www.pirate4x4.com/forum/showthread.php?t=1071185
Output shaft strength.
http://www.pirate4x4.com/forum/showthread.php?t=1028339
Modifications...
Rear disconnect ideas.
http://www.pirate4x4.com/forum/showthread.php?t=1066697
Underdrive ideas.
http://www.pirate4x4.com/forum/showthread.php?t=1023228
Discussion Starter #3
Probably the best selection of D18 parts on one page...
http://www.4wheelers.com/dana-18-c-344.html
I am trying to compile a list of the bearing numbers in the D18 currently.Any cross information people have would be helpful.
Front output, 1 required.
Ball bearing
NATIONAL Part # 206
Ball Bearing; Bore=1.1811", Outer Diameter=2.4409", Width=0.6299"
Snap ring?
Rear output, 2 required
Bearing
NATIONAL Part # 14131
Taper Bearing Cone; Bore=1.3125", Length=0.771", Radius=0.031"
Cup
NATIONAL Part # 14276
Taper Bearing Cup; Outer Diameter=2.717", Length=0.625", Radius=0.046"
I'd like to see info on dana 18 failures and fixes added as well.
I've seen issues from not having proper support on the offset output side of the case, causing the case to crack. Keeping a good bushing on there is really important.
Discussion Starter #5
I agree. I built my own torque-bushing using a universal poly bushings. So far it seems to work great.
I see you still using safety wire on the case bolts.I found after using a new gasket the T case to tranny bolts get loose after a few hours of use.I use lockwashers and brow goo Permatex on the bolts so they can be retightened.
On the case cracks,the D18 in my 2A has a cracked lower bolt boss.I believe this might have happened from careless assembly in the past...The tin lock plate holding the tranny shafts wasn't in proper position.Jammed the case from seating and cracked the boss when the bolt was tightened.
If you don't give a schitt about quality, and are only concerned with price then buy from one of the they have everything perceived online vendor whores who sell the Chinese reproduction crap (Omix).
If you want a complete kit with the highest quality bearings, and hardened shaft then buy this kit:
If you need gears? Get NOS Dana gears from Border parts Spring Valley, CA, or the guy in Oregon at www.G503.com or any vendor who has bought up the old stuff.
I've rebuilt my Dana 18 several times over the years. I teflon tape each bolt with Permatex non-hardening goo, and silicone the pan on. If you can, or have a Dana 18 that does not leak you are my hero.
Any 1966 single stick and later case should be retrofitted with an early twin stick front output housing. Removing the center pill between the shift rods will allow 2wd low range, so you only need to engage the front end when needed.
Discussion Starter #8
Any reviews of the 3.15 Tera Gearset? This is the route I am most likely to go with my T18/D18 'upgrade'.
Has anyone ever wired or locked the transmission to transfer case mounting bolts? I have seen more than one loosen up over the years.
A friend of mine found this...
From Chicago Rawhide/SKF: p/n 15450 (2.502OD, .50thick, 1.552ID) , CRWA1, which is a spring loaded wavseal type main lip with a light dirt exclusion outer lip. Nitrile compound only
That may be a good output seal alternative for slightly better sealing on the output yokes?
I've had the TeraLow 3.15:1 set for about 10 years, and I have a NOS 2.46:1 set I recently used for testing when I was searching for a vibration I had.
If you've got the money to spend at over $700 the buy them. I've never broken a gear and they've performed well.
However, it is really difficult to really tell a super big difference between the two. I really believe people running the Dana 20 benefit greater from its 2.03:1 ratio.
Bottomline: If the $700 can benefit somewhere else, use it there. TeraLow does make a great American made product, and I would buy it over any overseas reproduction.
i have an -almost- leak free D18... i get some seepage out of the shift tower rods. frankly i have no idea what to do about that, and well, i'm not that concerned.
if ya'll missed it in the build thread, this is the cross-member that i built.
this has worked out completely awesome. it was helpfull to have a spare case setting on the bench of ease of fab.
Discussion Starter #12
Interesting. For me, the 3.15 gearset is a difference between 83:1 with the stock gears ( T18, stock D18, and 5.38s ) and 107:1 with the tera gears ( T18, 3.15 gears, and 5.38s ).
Good to know they are a decent product. How is the intermediate shaft included in the TeraLow kit?
No intermediate shaft is included in the TeraLow set.
I've run both the cheap ones, and the hardened Novak shaft with quite a bit of power throughout the years. Because the 18 runs all power to the side via the intermediate gear these shafts wear fast. This is why I feel the hardened one is the only way to go.
I've got an automatic, so I don't worry about all the crawl ratio stuff. To me, crawl ration means you've got enough torque to really break stuff. I put in the TeraLow's to slow my Jeep down when coming down hill from high elevations, so I don't have to use the brakes.
Euroford:
That crossmember looks awesome. Great job!
Discussion Starter #15
Are you sure it still has oil in it?:D
thread drift... conversation at the tire shop yesterday:
Tire Dude: is that oil?
Me: yeah, from the left valve cover
TD: Is that coolant?
Me: yeah, from the heater connection
TD: Whats that?
ME: gear oil from the shift tower
TD: why is everything leaking?
ME: because I topped it off before i left the house.
(in my defense, it had been sitting for four hours, it was a couple of drips each, its not like i leave an oilsick in my wake, but still i had to laugh)
on intermediate shafts: i was able to get a NOS part from Mile High Jeep Rebuilders. I used it instead of the Novak part, as i was told the Novaks are good, but the NOS is the best. I havn't had it back apart to verify anything, but i have a couple thousand miles of trouble free use on the build so far.
Discussion Starter #17
I think I have the OEM intermediate shaft out of the D20 transfer case I cannibalized for the case. I need to look for that when I get home. From what I remember it was in REALLY good shape. That will work in a D18 conversion right?
What about a girdle for either a D18 or D20, anyone made one? I think it would be beneficial especially with a low gearset!
Discussion Starter #20 (Edited)
Tri-County gear, and maybe a few other companies, offered one at one time.
The unit basically tied the bottom cover bolts into the rear pto cover bolts. You couldn't use them with an overdrive or PTO. I have thought about making one for my new D18 project, but just don't know how much it would help with the newer D20 case?
Still available here?
http://www.tricountygear.com/tri-country/tcg_engineered.html
1 - 20 of 113 Posts
