1 - 4 of 4 Posts
Pavement Challenged
OK,
I got the spindles, hubs, rotors, calipers, pads, and now I need to figure out what people are using for the brake hose (75 K10 donor).
I have the Link from the top of the spindle to the caliper to connect, and that is only about 8", and the Cheby hoses for this application are 19".
So what is the right hose? (1 per side, not the on in the middle).
Thanks!
It's the same as a dana 44 disc swap.
You don't use that old block on the top of the knuckle, you'll need to weld a tab on the axle housing for the brake line and hard line to meet up.
Pavement Challenged
Uhhh... so what hose do you use for the 44 swap?
Nevemind... I see the Tom's part... I will get it there.
Thanks!
1 - 4 of 4 Posts
