1 - 6 of 6 Posts
What I found from searching is the bearing I need exists, but no luck with finding a part number for it (i'm at work and I didnt measure the ID and OD last night:shaking:) What I am trying to do is adapt a D300 to a TH400 using the stock 208 adapter and ouptut shaft using a 32 spline unput in the D300. Iwas planning on using 2 seals facing opposite directions in the input retainer to seal it, but the idea of a sealed bearing solves my problem w/o having to bore the retainter to fit 2 seals (the retainer is stepped behind the first seal). I know it would PROBABLY be fine with the single seal, but i'd rather not fuk around.
Thanks in advance
6209 from ntn just tell them you need a sealed bearing i just put one in my 300 took the seals out but i cant remember the prefix on it
bearing
6209 llu by NTN, 6209 2rs by SKF, 6209 DDU by NSK - any Industrial Distributor should have them - Motion Industries is one, or an Electric Motor Rewind shop would also have them but you'll probably pay more.
PM me if you need one, we keep them in stock in either sealed or sheilded.
1 - 6 of 6 Posts
