1 - 9 of 9 Posts
I got greasable but the grease zerk in the upper does not clear the u-joint, they must know this is an issue cause they also give you a small plug for the grease hole. lowers are just fine and greasable.
IH/Rover Moderator
Spicers. Like your really going to take the time to disassemble the brakes and outers and axle, them remove the plug and install the zerk to grease your upper ball joint! Spicers last and there strength is known. Just like u-joints the zerk hole weakens the part.
Old Scout said:
Spicers. Like your really going to take the time to disassemble the brakes and outers and axle, them remove the plug and install the zerk to grease your upper ball joint! .
Grease them each time you have it apart for a busted axleshaft... With a D44, that opportunity will certainly arise often enough :D .
IH/Rover Moderator
Sorry I have an ARB ,superior axles and ox joints, so it won't be that often. :flipoff2:
1 - 9 of 9 Posts
