These axles are stock width for a YJ which I used for about 3yrs. They still have all the mounts for the springs, fittings for the lockers which are ARB, drag link and tie rod which are aluminum with heim joints. The front diff cover is a "Crane" and the rear has a Rock Ring with a clear cover underneath. The rear shafts are superior chormoly with the 5 on 4 1/2 or optional 5 on 5 1/2 bolt pattern. The front shafts are Warn Chromoly with 5 on 4 1/2 bolt pattern. The front also has Warn hubs. The gears are 4:10. Everything works great on these including the air locker and brakes which have a disc conversion on the rear. I am moving these because I've upgraded to a D60, but they have worked great for me. These were buillt by Currie Enterprises about three years ago. I paid $4,300 for the front axle and about $3,300 for the rear. I know you can never get what you paid for out of old parts, but I still want $4500 for the both of them.
Questions: e-mail me [email protected] I can send picts.
I'm located in Idaho Falls, ID zip 83404
