1 - 4 of 4 Posts
A guy at my local dealer says he has a D44 with vacuum disco that also has drivers side drop and high pinion. He says he doesn't know what it came out of and it will take a couple of days for him to get me the WMS spacings. He says it's a 5x5.5 pattern.
I don't mind cutting the housing down or even retubing and getting rid of the disco, but what the heck would this have come out of? Or has he been drinking his bath water?
Yes, I know D44's aren't as good as D60's but I don't have the $$$ to do a D60 right now. I also did a fair amount of searching for the D44 w/disco. One site said something about a waggy in the early 80's.
I thought that the recent dodges were the only CAD D44 out there with the driver's offset and the disco on the tube? Waggys have that funky diff that looks like someone tried to cross breed a scuba regulator with a normal 44 housing...
Bob
· Premium Member
Early Dodges had passenger drop and drivers side disco on the tube. Most likely, he has one of those, and is looking at it upside down. Makes it HP drivers drop huh? If it's cheap, grab it and rape the kuckles and brakes off of it. They are flat tops and 5x5.5 pattern. Way better option then going with a Chevy/Ford combination to get 5x5.5 and flat tops. At least all your parts come from the same application, makes buying bearings, pads, etc easier.
If you can call him at home, have him rotate the pinion clockwise. Bet the rotors turn backwards.
1 - 4 of 4 Posts
