1 - 11 of 11 Posts
I did some searching and can't find out how tight the outer hub nut on the D44 should be. I have the 1/2 inch impact on it right now and can't get it to loosen. it is really tight. I can't see any locking ring or pins. The locking pins are on the first nut right? Help!!!
They might have used a regular nut with the big washer behind it, bent over the nut sides. That's how the early ones are. I would think that a 1/2" impact would tear that apart pretty easy unless the slot in the washer got twisted into the threads.
I looked for any kind of locking washer that could be where I could bend it or some thing. but it is not there. In my searches I came across exactly what it looks like. It is an inner nut with a pin and a washer with a bunch of holes that once you set the bearing nut(inner) to the right pressure you put the washer on and line it up with the pin then the outer nut just screws on and pushes against the washer, locking it into place? I can't get the damn thing to move! rrrrrrrrrrrrrrrrrrr!!!
mikecj5cj8 said:
Remember: Righty tighty, lefty loosey :flipoff2: .......maybe your impact is in the righty tighty mode!
I have been using an impact wrench for 20+ years I know how to operate it! :flipoff2:
I tried the breaker bar first and could not keep the socket on it.
1 - 11 of 11 Posts
