I'm putting together a waggy 44 to put in my YJ. When installing the wheels hubs, you have two nuts and a washer. What order do they go in. I was thinking the washer first and then the nuts. Also how tight should the first nuts be.
Thanks
as for how tight the first nut should be there are actual in/ft lbs of torque but i usualy tighten the first nut while spinning the rotor. when it starts to bind(feel resistance) and then back off 1/8 of a turn.
when it comes to the secound nut i will tighten till snug and then tighten 1/4 turn and then untill it lines up with a locking hole (always tighten TO a locking hole/tab never loosen to one)
