started life as a jeep J10 Quadratrac axle. Narrowed to 60"WMS. Diff is offset to passenger side to work with a dana 18 t case or other offset t case. Passenger tube uses shaft from Warn full float kit, driver side has custom 30 spline shaft from Dutchman. Has Warn full float kit, spool with 4.56 gears. $2500. may be up for piece meailng. Brakes could be included for more $. they are Suzuki disc with Nissan 300 calipers. has caliper mount bolted to axle flange end. Narrowing was professionally done with a true bar. Axle is straight. Located 1 hour west of Denver best to call or text 970-485-9016 can send pics. Brakes were very balanced in a cj21 with a v6, 35 inch tires, and gm mid 80's full size pickup discs on front.
