1 - 16 of 16 Posts
Alright I picked up a fullsize D44 for free, the guy was moving and needed to get rid of it. I wanted to put it on my xj but the pumpkin is on the wrong side. So I want to flip it and run reverse cut gears. If I do this, I will have to cut the knuckles and switch them around right:confused:
you can flip the axle. but you gotta turn the motor around too ;) seriously!
if you did a rear engine conversion you could run upside down axles....BUTTTTTTT at that time you would want to run that 44 in the back and put knuckles on maybe a 9" for the front :D you still wanna turn the axle over? :D
all you need is a reverse rotation front driveshaft. been done many times. just do the flip, take your old front 'shaft off and carry it to a machine shop. tell them you want it reverse-rotation. they will know what to do. may take a while, as you have to run Austrailian U-joints at the case yoke to get it to run backwards. shipping on them is usually 12 weeks.
BTW, as a newb can i flog other newbs? or should i wait...:question:
Discussion Starter · #11 ·
I knew that was going to happen! So when I buy the inverted brake fluid would that also be a good time to buy some inverted gear oil:flipoff2: Thanks for nothin fuckers!
JC, some time these guys are big asses and just flame away w/o even thinking to help. don't worry about them. HERE is a link to a write-up that a guy in my club did on the exact thing.
SUCKA!!!! :blackflipoff2: ;)
If you knew it was going to happen, why did you ask? Not flaming, not old enough, just wondering:confused:
1 - 16 of 16 Posts
