A note on studs:
Basically when they list studs, they list the thread and pitch of the studs (i.e.: 9/16-18 or whatever), the length of the stud (which is the length of
the part the lug nuts thread on to), and diameter of the 'knurl', which is the splined part of the stud, and often the length of the knurl (called the
shoulder length).
Dorman part # 610 - 283 is the part number for the STANDARD 1 ton Chevy, it fits 77-91 Chevy trucks. 9/16-18 thread, 2 17/32
long, .650 shoulder, 15/16 shoulder length.
Dorman part # 610 - 303 - fits 77-91 Chevy trucks. 9/16-18 thread, 3 inches long, .678 shoulder, 15/16 shoulder length. It is
identical in most measurements (including thread) to the 610-283, except that it is somewhat longer and has a knurl of .678. In actuality, the ones I measured never mic'd to more than .672.
My friend Chad who did a DRW-SRW conversion reports:
"If you find that even Dorman 303 is too small, Bicknell Racing Products sells a wheel stud, part number BRP2059, which is 5/8 Course thread, 2.75
inches long, .685 shoulder with a .800 shoulder length. This stud was meant to be used in a hole drilled out to 43/64, which is the exact size of the
hole I used, so this is the stud I ended up using, and I can report that it fits quite nicely into a 43/64 hole. They also sell another wheel stud,
BRP2075, which is exactly the same, but 3.75 inches long. The shorter stud worked fine in my application, but some people may want more stud sticking
out. BRP2051 is the lug nut that matches, but I think any 5/8 course lug nut would work fine."
The important thing here is to select the studs you need to use FIRST, measure the knurl diameter carefully (mic it) and then have the holes drilled slightly undersize for a proper tight interference fit. Standard class V interference fit (tight - semi-perm. assembly) the interference (shaft bigger than hole) should be between 3 and 18 thou. Given this, and the fact that the measurement of the knurl will be the major diameter of the splines, I would shoot for a 15 thou undersize hole. Given the measured knurl size of .672, this would mean a hole diameter of .657. A 21/32 drill bit is .656250, yielding an interference fit of 15.7 thou. That should be just about perfect, but MEASURE TWICE, drill once!
