1 - 20 of 40 Posts
<IMG width=574 height=252 SRC="http://www.pirate4x4.com/ubb/uploads/d60hs.JPG">
<IMG width=436 height=316 SRC="http://www.pirate4x4.com/ubb/uploads/d60hs1.JPG">
used avalanche arms with 1 inch spacers and there tie rod and drag link. the pitman arm is a yj 4 inch drop drilled to have a 3/4 inch hole
Just make sure that pitman arm dont tangle with that spring at full left turn. Looks good. Are you planning on sticking with the double tie rod? Beefy! <IMG SRC="smilies/biggrin.gif" border="0">
Can I ask a newbie type question? If the tie rod is that close to center, does it put more stress into turning it? I've wanted to do mine that way but like you said, I'm afraid that the drag link will enterfear with it...
the stock tie rods coming off, but its raining and i done feel like getting even more wet. the pitman and springs work fine its actually the same pitman i used for my d44 high steer set up i ran before i put the d60 in.
Originally posted by Leader:
<STRONG>Can I ask a newbie type question? If the tie rod is that close to center, does it put more stress into turning it? I've wanted to do mine that way but like you said, I'm afraid that the drag link will enterfear with it...</STRONG>
Yep like you said tie rod closer to the kingpins means more stress in the tierod and rod ends. If you make the distance between the rod end and the kingpin half of what it originally was you double the stress in the rod end.
Originally posted by Gordon:
<STRONG>Yep like you said tie rod closer to the kingpins means more stress in the tierod and rod ends. If you make the distance between the rod end and the kingpin half of what it originally was you double the stress in the rod end.</STRONG>
And, you also double the amount of steering input needed to move the tires. Looks awfully short to me, but what do I know.
<IMG width=498 height=308 SRC="http://www.pirate4x4.com/ubb/uploads/d60hs2.JPG">
it is shorter but not as bad as it looked in the photo, if i find i dont like the feel of it were it is i can move it thats the nice part about the avalanche arms
Discussion Starter · #9 ·
like i said once i get it out on the trail i can test it, i think your all just jealous <IMG SRC="smilies/thefinger.gif" border="0">
I'm just a stupid carpenter, but, I don't see how there is any more stress on the knuckle. I understand there is more stress on the joint, due to the reduced leverage, but to me, the knuckle is doing the same amount of work either way...please explain.
My hydro set-up is very close to the same geometry, and I did spit out a hiem joint at the badlands last week, but it was a worn cheapo, and I was pretty hard on the whole rig, so I blew it off.
Originally posted by yjtj:
[QB]<IMG width=498 height=308 SRC="http://www.pirate4x4.com/ubb/uploads/d60hs2.JPG">
<STRONG>like i said once i get it out on the trail i can test it, i think your all just jealous <IMG SRC="smilies/thefinger.gif" border="0"></STRONG>
Na I already have high steer <IMG SRC="smilies/thefinger.gif" border="0">
Jealous No pity yes.I understand that you are suposed to put the tierod at the same distance from the center of the kingpin/balljoint as the stock tierod location. That is the optimum steering leverage and if you move it towards the center of... then it takes less input but more torque to turn tighter. Move it away... and that takes less torque and more input or further movement at the pitman which can only be increased by a longer pitman arm, which takes more torque to move. The auto manufacturers spent alot of time and money developing a steering system for a reason, in this case its best to keep it as close to stock dimensions as possible.Am I right steering pros?????
By the way it looks nice and Id just move them out but you will work it out
[ 10-16-2001: Message edited by: wheelinjp ]
Where the tie rod is located has nothing to do with steering leverage (aka steering ratio). Steering ratio is affected by where the draglink is mounted on the steering arm and by the length of the pitman arm.
[ 10-16-2001: Message edited by: BenW ]
Discussion Starter · #16 ·
everyone with suggestions get your own d60 and do it the way you want, mines staying the way it is
<STRONG>everyone with suggestions get your own d60 and do it the way you want, mines staying the way it is</STRONG>
<IMG SRC="smilies/rolleyes.gif" border="0"> So... if you aren't open to suggestions/criticism then why the hell did you post this? To brag? Nothing there to brag about. All I see is a missed opportunity for a badass steering system (ala Ant) with the tie-rod BEHIND the axle. I don't like the SRE's either, but like ya said it's yours so who cares what we think. Being an ass when you receive constructive criticism is no way to make friends, on or off the trail. Quit being a stubborn ass and open your eyes to the suggestions that have been offered. <IMG SRC="smilies/beer.gif" border="0">
And yes you are putting a LOT more stress on that knuckle (moreso the driver's knuckle). Simple force balance. The closer the tie-rod to the king pin the higher the force required for a given torque. And where is that force reacted? The knuckle/joints. Like ya said though, you'll figure it out on the trail...
[ 10-16-2001: Message edited by: Eric Ruhl ]
at the dixe run a couple weeks ago, there was a guy with hydro assist that broke the top of his d-60 knuckle off. it got me thinking that i might just run dual tie rods like your pic shows with hydro assist on the lower one to prevent tearing the top of the knuckle off. the only concern is catching a lotta rocks..
Hey elusive!
If the cylinder doesn't stop before or at the same point as the knuckle(s) stop it will tear stuff apart, no matter how many tie rods you run.
ps...was it You that fell off the mountian on trail #1 ? wtf ?
Right on Eric.
He knows how to get to the point and bring it all into focus. It least when he does figure it out on the trail a 60 knuckle is an easy item to get from most anyone on the trail. NOT
Move the box ahead and fix it befor you a burden on you wheeling buddies and the people that have to get around you when it is broke in the middle of the trail.
1 - 20 of 40 Posts
