81 - 100 of 114 Posts
Can I order one of these springless arms with your springless cap? I'm only doing crossover but want to replace the weak Ford OE knuckles for a set of Solids... I'll need the arm tapered for a Chevy drag link and the mounting hardware for them. Can't tell in your pictures but are the arm and cap mounting holes chamfered for studs and cone washers or are they flat or countersunk for bolts and washers like the Solid arms?
CNC Machine Shop
Discussion Starter #93
Yes, You can order single arm and single cap. And I can drill for TRE in any location. And all of my SOLID arms and caps are not countersunk for studs. Just left standard to use grade 8 bolts as per SOLID's recommendations.
