1 - 5 of 5 Posts
I just got a D60 FF that has 30 spline shafts. I want to convert it to 35 spline. Should i bore out the original spindles or can i buy 35 spline spindles and have them fit? Which is stronger??
Bore out the originals.
Or call up Sandy Cone and get a set of his trick alloy spindles and hubs.
cmk
You can bore your spindles.
I bored mine to 1.610", just keep it in that range and you'll be OK.
Jeepin951 said:
Are 40 spline shafts still 1.5" diameter??
No, 40 spline is more like 1.710"
37 spline (D80 side gears) are 1.583"
1 - 5 of 5 Posts
