1 - 10 of 10 Posts
OK, I've found a dually 14 bolt 1 ton rear end. This means 35 spline, full floater, and according to sources on THIS board, 62 inches wide. If I got it I would shave it for more ground clearance.
However, to me there is no point getting a 62 inch rear end if I can't get a front to match. So my question is, how narrow can one make a Ford D60 for all practical purposes? Can I make it ~62 inches to match the rear just by shortening the long side?
I'm assuming that both will have the same 8 bolt front pattern.
Thanks for any information. By the way, this would be going into a YJ which currently has wagoneer D44s (~60 inches wide).
Chad
Chad,
I just narrowed one down to 60" so leaving it at 62" Should be no problem. You should be able to get by just narrowing the long side. I narrowed both but then I had to swap the tubes side to side for a passenger side drop on the diff.
<IMG width=216 height=162 SRC="http://www.pirate4x4.com/ubb/uploads/sixty15s.jpg">
Mike
Mike,
What kind of jig do you have?, did you make your own jig? How.
Thanks
Mike
BlueYJ <IMG SRC="smilies/glasses.gif" border="0">
I run the setup you are talking about. not all dually 14bolt rears are 62" wide so you better make sure! infact most are 67" wide. it took me a while to find mine. the cab and chassis version is the 62" wide version. being that you run a yj you need to cut down both sides. take 3.5" off each end and she'll bolt in. i run a cj but i had already outboarded my springs for the scout d44 i was running and the chevy 60 spring with was the same so i didn't mess with spring location (you with the yj frame won't have to either). like i said 3.5" off each side of a 69" wide dana60 and that puts it at 62".
Hey Mike thanks for the link, your site has allot of great info.
Originally posted by ChadLloyd:
<STRONG>OK, I've found a dually 14 bolt 1 ton rear end. This means 35 spline, full floater, and according to sources on THIS board, 62 inches wide. If I got it I would shave it for more ground clearance.
Chad</STRONG>
I had a 71 in front 60 and shortened the long side ONLY to 64. I did have to outboard my springs tho. But it can be done. <IMG SRC="smilies/smile.gif" border="0">
<IMG SRC="smilies/massey.gif" border="0">
1 - 10 of 10 Posts
