Fine-tuning the rear suspension travel of your Jeep XJ has never been easier, thanks to Rough Country's Jeep XJ Shackle Relocation Kit. Featuring a set of frame brackets and shackle brackets, this kit relocates the stock shackle positioning, preventing it from bottoming out against the unibody. Once installed, the shackle is capable of a much greater range of motion, offering increased articulation for off-road use. Whether you run a stock or aftermarket shackle, need to accommodate various sized leaf springs, or want to use in conjunction with a separate lift kit, these shackle brackets offer 5 different mounting points which allow you to select the shackle angle you prefer with the equipment you have. Depending on which mounting point you select, this kit can provide up to 1.5" of lift as well. These powder coated components feature 100% bolt-on installation, making them one of the easiest Shackle Kits to install in the industry, all at an industry leading price.
CLICK => Jeep XJ Shackle Relocation Kit - NOW $89.95
This special will expire at 12/18/2011 at noon Eastern time.
