1 - 8 of 8 Posts
I bought a set of stock H2 wheels, and I didn't realize the lug holes are 14mm vs. the 1/2" studs on my dana 60.
This is what I've come up with.
Redrill the holes in the front rotors and hubs to fit 14mm studs and redrill the hubs in the rear and use front rotors from a 3500 ( I wanted to convert to disc in the rear anyhow)
Can anyone offer any help? The holes are tapered. Is there a lug nut with a larger head on it?
I've tried Mag style 1/2" lugs and they're no good either.
thanks
I went to Krapen and found the studs for a F350 work Great. Pretty damn long though and pricey. About $3 each. I'm going to shop around to see if I can find a cheaper stud.
Gawd 32 x $3 =$96 plus nuts!!! ouch Luckily I can return some other studs I didn't install.
1 - 8 of 8 Posts
