1 - 10 of 10 Posts
reduced price, missing yolk
Selling a DANA 70 rear axle
This is a mid 80s axle
D70-3HD
4.10 gear ratio, open diff
35 spline axle shafts
Approx. 66.5" wms x wms
dissembled
complete except missing yolk
B.O.M# = 605345-7
****** this axle is designed for 4.10 ratio and higher (lower # gear ratios)
4.10 is the max, unless you run a ring spacer, or other mods. (Similar to a Dana 61), but with 35 spline shafts...:smokin:
$80
located in Northern ca near Auburn
Local pick-up only..:smokin:
Can you measure the pinion offset on this diff? What is the tube size? I might be interested if it's 31/32 offset and 4" tubes. Thanks.
Discussion Starter #4
from the info online :
*70-3HD (.969" offset, '87+)
I believe it is a 4" tube, but I will check
1 - 10 of 10 Posts
