1 - 8 of 8 Posts
Has anyone ever heard of or done a TJ axle shaft swap in a YJ? I have heard that a TJ Dana 30 axle shaft will fit in place of the YJ vacuum disco axle shaft eliminating the disco.
Yes it works, you just need to strip the vacume disconnect guts and install an inner axle seal in the pumpkin.
Thanks for the help. Can you run a TJ axle shaft on 1 side and a YJ on the other. I know the u joints are different but this is just a temporary fix till I can afford a super 30 kit and locker.
yes, when I did it you had to get the seal from Warn.
yes, if you want to.
1 - 8 of 8 Posts
