1 - 9 of 9 Posts
Just finished installing High Angle Driveline's new Dana 300 driveshaft mounted ebrake and it works like a champ... Here are a few pics, only took about 30 min to install.
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/ebrakleft.jpg">
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/ebrakright.jpg">
If you are looking for a e-brake solution this IS the one... <IMG SRC="smilies/glasses.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0">
the kit -rotor -caliper and braket for the long tail 300 is 289.00 and then you need a flange and one ton c/v to finish it off- $ depend on what diff and so on - Jess <IMG SRC="smilies/biggrin.gif" border="0">
Originally posted by onetoncv:
<STRONG>thanks for posting up mark- i was wondering how it went- how was the cable to the caliper lever? Jess <IMG SRC="smilies/biggrin.gif" border="0"></STRONG>
I was able to use the stock e-brake cable, routed outside the frame around the center body mount, welded a flat washer on the frame and used a brake line clip the hold the cable to the washer. I used the stock 5/16" adjusting rod to connect it to the lever. Works like a champ. Nice design.. BTW my vent line was already tapped ??? Only mod a had to make was to elongate one of the holes in the brace that goes to the bolts on the lower plate on the ebrake. So far that was the easiest store bought part I have installed so far..
Thanks Jesse....
mark- i am happy it worked out like it did - we did think it thru and the tapped vent issue- the case we used looked like it could have been tapped but it was not quite there- so we tapped it 1/8 pipe- Jess
<STRONG>By the way my new empoloyee designed a good part of that kit - seeing how we did the first one on his dana 300 - thanks eric!</STRONG>
Now I just have to get off my butt and get the thing installed. Glad to know it works anyway <IMG SRC="smilies/biggrin.gif" border="0">
DAM, right when I talked myself out of a inverted Dana 300 you go and show me this.
Thanks now I have to save up even more.
Chanting>>>>> I will have an emergency brake. I will have an emergency brake. <IMG SRC="smilies/biggrin.gif" border="0">
Just waiting for the cash to roll in. I dont feel like charging anymore right now.
1 - 9 of 9 Posts
