1 - 20 of 154 Posts
Dana 300 flip (cheap & easy)
Stainless twin stick shifter kit for a flipped Dana 300 .
No longer well one have to spend big $$$ to flip a Dana 300 to drivers drop. with this "VARY simple" shifter one can just bolt the sticks onto a stock Dana 300
and flip it to drivers drop.
$169 with shipping
Duffy
D.D.Machine
(360)779-2500
Paypal name is [email protected]
(to get front drive only one must pull the shift interlocks)
"All Weeee Drive!"
Ok, now you got me really interested Duffy.
I was planning on your 241 doubler (to a Ford 205).
This would be waaaaayyyy better.
Big question though, when flipping a D300 I thought the shift rails had to be relocated to the top of the case (in a plate inbetween the original drain cover) so that the fluid doesn't leak out of the rail seals.
What is the solution.
Hey Duff,
Nice job.
Quick question, how does the stock ft bearing retainer/shifter tower have to be modified to fit the shifter bracket?
Also, could you post a pic of just the bracket (unmounted).
Thanks,
Jimmy
d.d.machine said:
There is no mods made to the case the shifters are 100% bolt on.
( its simple to make somethang work, its hard to make somethang simple)
OK.
It might be because the pic is small, and from face on (not a side shot), but it didn't look like the stock cast shifter hanger bracket was still there.
edit, I compared your pics to some others (my D300's bracket is long gone, so I can't compare it to that), and I can see the bracket now.
Thanks,
Jimmy
Is there enough room to run a 1350 cv on the front output?
1 - 20 of 154 Posts
