1 - 8 of 8 Posts
Just finished doing the D300 swap into the XJ a few weeks ago. I expected initial heat issues with the gears breaking in, but was concerned about how hot the case got tonight during a 2 hour drive. It got so hot I couldn't touch it but for a second. I just flushed and replaced the gear oil, as I just had hit 500mi on the new 4:1 gears. Any suggestions? Should I be concerned?
Btw - I filled with 2 quarts of Valvoline 75w-90 full Synthetic. D300 IS clocked. Thanks yall.
I wondered the same thing when I did the sye on my 231. Thing is, I never checked the temp before I did the swap so had nothing to compare it too. Then I figured that it's gonna get pretty hot when connected to the auto tranny and motor all of which get too hot to touch.
when i had my np231 before the SYE it got really hot and the same after i didnt see a real big change in heat
but now that i have a 300 with 4to1 i am going to wonder the same
also would synthetic be better to run in them? something like torco?
use the search
someone had this problem about two months ago. It was somethign about a depth on the output shaft? or something? Something had zero runout and it should have had a little.
1 - 8 of 8 Posts
