1 - 9 of 9 Posts
Hi Guy's
Just started to look at rebuilding my D-300, I have done some web searching and did a dealer check, so far I have not found a source for a set of stock shift rails :( Most the genaric pats houses (4Wd ...) don't seem to list them either. Anyone by chance know a source ?
thanks Mike D.
Thank you,
Jeep has none, checked that first, but Quadratec did list them.
Thanks.
Mike D.
If you're rebuilding your D300 just get the Advance Adapter twin-stick kit. It comes with new shift rails that are threaded on the ends for their heim-joint shifters rather than those cheap tabs on OEM rails that can break off.
Thinking about it, I do have an old broom stick, if I whitteled that baby down some, that should work :p
Aren't they just a standard diameter cold rolled round bar? Grind & hammer to fit.
Bummer Quadratec, is telling me they are backordered :(
Twin sticks have there place, and this rig is not the place for a twin stick, this one has to be simple to operate with a dumb driver (me included)
Mike D.
1 - 9 of 9 Posts
