1 - 9 of 9 Posts
Dana 44 (60" WMS to WMS)Drivers side pumkin. Welded spring over (6°) for YJ. 4.56 gears, with 1 complete spare short side shaft with outer, and one moser cut long inner shaft. New lincoln locked Carrier, Dana Gears and SuperWinch Hubs. It also has Full size ford Disc Brakes with a 5 on 5.5
bolt pattern. It also has new Crossover steering built with DOM Tubing with 3/4" heavy duty heim joints on tie rod and drag link - Comes with spare carrier with 3.54 gears.
Rear 9" 28 Spline, Superior 4.56 gears, Mini Spooled, with new heavy duty 1310 yoke, Drum brakes, New wheel cylinders, Spring Mounts are welded spring over for YJ. 60" WMS to WMS - Comes with spare 9" center section with 3.54 gears.
Perfect for spring over YJ. Will sell both for 2000 or will seperate if there is a buyer for both. These axles are perfect, and are very strong.
1 - 9 of 9 Posts
