1 - 3 of 3 Posts
Front Ford 3/4 ton Dana 44 set up for 3link and coilovers (flat top knuckles, high steer arm on passenger knuckle, SOLID diff cover, ARB Air Locker, Nitro Gear 4.88 gears, stock shafts with Alloy USA ujoints, WARN manual hubs, 3/4 ton dual piston calipers, 1.5"x.25" DOM tie rod and drag link with chevy 1 ton tie rod ends, diff cover and tie rod set up with mounts to run hydro assist) measures 64" from WMS
$1800
Rear Ford full float 3/4 ton Dana 60 set up with truss for triangulated 4 link (has mounts for air shocks but also has coil buckets for running coil springs, SOLID diff cover, Detroit full case locker, Nitro Gear 4.88 gears, stock 30 spline shafts with a set of spares, disc brake conversion with 3/4 ton brake calipers) measures 66" from WMS
$800
Located in Washington
text or call me at 253-334-5163
1 - 3 of 3 Posts
