Front-Dana 44, full Detriot Locker, Alloy 4.56 gears, Timken bearings, Warn
Premium hubs, Clayton High-Clearance axle brackets and track bar bracket,
Clayton lower spring retainers, less than 500 miles on locker, gears, calipers,
rotors, pads, hubs, inner and outter bearings, seal, spindles, drag link and
drag link end. It also comes with the drag link, tie rod, and complete set of
spare front shafts with u-joints installed. 5x5.5" 61" wms to wms Price is $1000 firm
Rear-Full floating Dana 44 from a TJ, full Detriot Locker, 4.56 Alloy gears,
Timken bearings, Warn full-floating kit, Warn Drive Flanges, Warn chromoly
shafts, Clayton High Clearance axle brackets with lower spring retainers,
Clayton axle truss, 11" drum brakes with less than 20 miles on new shoes and
inner driver side wheel bearing and seal. I also have a spare set of chromoly
shafts that will be included with the axle. 5x5.5" 60" from wms to wms. Price is $1100 firm. Both axles are still in my Jeep as we speak and work perfect.
The front will bolt in to any XJ, TJ, ZJ. The rear will bolt in to any TJ or YJ with a Clayton kit.
Located in Southington, CT 06489 Free pick up or will ship on your dime. Feel free to ask any questions. -Steve joker4ink@cox.net
