dana 44 frount axle
2281 Views 3 Replies 3 Participants Last post by  yjdon
I have a mid 70's dodge dana 44 frount axle with the big nut thing, and want to put hubs on it, how do I do that. A yes I searched and came up with very little. thanks
1 - 4 of 4 Posts
Get everything from the knuckles out off a 80 to 93 Dodge and swap on.. Thats the easiest and cheapest..
Re: Re: dana 44 frount axle
Agreed.
If this is a 1/2 ton, you'll need the matching rear axle shafts and drums (for the correct axle) if you want the same bolt pattern front and rear. Then of course you'll need new wheels.
this will work even if it's a 3/4 ton model.I plan on putting a 14 bolt ff on the rear of my jeep with 44 front thanks don
1 - 4 of 4 Posts
