1 - 5 of 5 Posts
I have a clean Dana 44 from a cherokee, it has the larger brakes & thicker and larger axle tubes then the TJ D44. Reg ole jeep 5x4.5 wheel pattern.
It has all new diff bearings and seal, new spool, spicer 3.73 gears, turned drums, and painted black. Ready to run in a Cherokee.
450$ as is.
575$ with any other ratio.
425$ with very good cond trac-lok posi.
Can remove and weld on new perches for a YJ or ? Or all new mounts and such for a TJ also. If interested in this let me know.
Axle is in So cali (Anaheim), will ship on your $...
How much to set it up for a TJ with 4.10 gears? I want the spool. Also need it shipped to florida on my dime.
How much for the axle set up for TJ and shipped to 84123?
Well I dont like to do TJ brackets without the Jeep to base it off and set the pinion angle for it.
I will sell ya the axle for 450, complete axle bracket kit for 250 and send it all to you for 90$. then you have a local install it all.
1 - 5 of 5 Posts
