I am putting on a high steer setup on my scrambler. I bought a set of scout Dana 44 axles with Dana 30 outers (6 bolt spindles). I then purchased a set of flat top Dana 44 knuckles. I then had to purchase a set of chevy brake caliper brackets (i have a set of wagoneer brake caliper brackets as well, but they basically are the same thing). I set everything up with the chevy calipers, brake pads, etc., and first tried it with the dana 30 rotors. the rotors are too thin and with the caliper piston compressed to fill the gap, the pins are almost fully extended with the possibility of falling out with a little wear.
I then tried chevy 1/2 ton rotors, but the chevy rotors are 6 lug. I want to keep the same 5x5.5 wheel pattern. I also tried chevy S-10 rotors (which are 5x5.5) but they are too deep with backspacing and rub on the bracket.
What rotors does everyone use to convert to dana 44 highsteer knuckles while keeping the 5x5.5 bolt pattern?
