1 - 13 of 13 Posts
Some 1/2 ton GMCs, around '67 and '68 used 44s in the rear. Not sure of the axle spline count on those. I would look at full-size Jeeps, as mentioned above.
What axle are you running in the front so we have an Idea of what width your at? Fullsize Jeeps (cherokees,waggy,the p/u commanche? had some ) had 44s in the rear.
Got any pics of your 10, I have a s10 blazer with fullwidth d60ff rear and HP44 front on 37's w/hummer rims. :D
Discussion Starter · #11 ·
i want to end up with 5 on 5.5 lug pattern. i talked to gradys off road cuz theyre bout an hour and a half away from me and he was talkin bout cuttin down a fullsize jeep 44 and possibly doin the toyota outer part and stickin that on so that way i could have a dana 44 with 11" toy drum brakes. i forgot which he said was cheaper. i want the axle to be stock width, or 1" wider per side MAX. i want to keep same trac width as much as possible
Chevy's don't use Dana 44 rear axles, if they did it had to be before 67 sometime. The 12 bolt was used from 67-80ish.
If it is a old 44 it will have the not so good 19 spline axles. Look in a Scout or Jeep Truck. Look for stuff in the mid to late 70's and newer.
9" Axles do have a low pinion entrance and won't help you drive shaft angles.
Cutting down a full size Jeep or IH truck rear would be 1 option. Both tubes & shafts would need to be cut down & Toy drums probably need to be redrilled. Make sure the shafts do'nt have a taper next to the splines where the new splines would be. Not sure if rears have the taper like stock fronts or not.
Another option I would look at is a Waggy rear. They are already the right width, but 6 lug. It would need the flanges redrilled. I think '87 to '91 would have a centered 44. The AMC 20 in the '80 to '86 is roughly equivelant to a 44 (not like the 20's in a CJ), but not as many ratios available.
There's the Scout 44, but may be a little too narrow.
I used a Chevelle 12bolt. It's the right width, but has 5 x 4.75 to match the IFS front.
I do'nt know what you are useing in front or if you already have new wheels. Going 6 lug might be your best bet. You could use front & rear Waggys.
1 - 13 of 13 Posts
