Yea that's true. I hadn't thought about that. Anbody know the outside diameter of the XJ, YJ, TJ, Dana 30 rotors. Or more specifically, does anyone know how similar these rotors are to the Chevy 1/2 ton rotors?oldjeep said:I suspect that a D30 rotor would work, depending on what size center hole you need.
CheapXJ said:mid-late 70's 1/2 ton dodge pickups with fulltime 4wd
(i know for a fact that the 78's like this were 5 on 4.5")
if you want to try Jeep rotors, 92+ XJ rotors had a larger inside diameter for the rotor "hat"
there were also two different measures of backspacing on the rotors (XJ, 92-98 and TJ are different, TJ being shallower)
What's a slide over rotor?Hick said:Also dodge stealths had a slide over rotor. I was going to use mine.. but ended up going 8 lug.. same size as a dodge half ton rotor, just 1" think (**I THINK***).. so it uses the eldorado or monte carlo callipers.. if you want both, drop me a PM.
Garrett
