1 - 2 of 2 Posts
I have spent a long time searching and have not had any luck so I will see how flamed I get for this. I am looking for someone who has dimensions for high steer arms for a dana 44. I am looking for drawings of double arms so I can mount the tie rod (and Ram) behind the axle, however just some drawings with how the studs are layed out would be great. Also I will be running these on my YJ that is spring over with stock wagoneer springs will I need spacers if I plan on making the arms out of 1" thick steel, or will the tie rod and drag link clear without the spacer. I will be using 1.25" thick rod for steering linkage. Thanks for your help.
Kris
If you've searched, then you've found this, because that's how I found it, and I've posted it more than once, but here it is again.
1 - 2 of 2 Posts
