Wilson said:ahh, I was bored and did it for you.....
some info
The standard reamer should work, just watch your depth as that will determine the depth and pitch of the final taper.
He wants to drill the tappered hole that the split cone washer goes in. He isn't looking for a cone washer.......I don't know what you readRockcrawler_101 said:Hay is it the little cones with the little slice down one side then i would go to your junk yard and get them out of a old dodge 4x4. i know they have them on the driver side for the steering. I would bet chevy also has them, but know dodge has them.
Originally posted by TORC
He's not reaming holes for tie rod ends. He is asking about the cone washers that are used to attach the steering arm to the knuckle. It is not the same 1.5" per foot taper as the tie rod ends.
thanks that sucks though I was hoping to not spend more that 50 or so I will look around thoughOriginally posted by Mr.N
Go check out BillaVists web page. He lists different tappers. You'll find tow that are close, real close. Now try to find a place that has them, good luck as I gave up.
