I have a complete Dana 44 (wagoneer) to swap under the Toyota, but it's gears are 2.72. I was going to use a toy housing I have and the Toyota diff, with the Dana knuckles welded on. What problems will I run into with this??
Would it be cheaper to just change the gears in the Dana 44, assuming I encounter no labor charge for the gear swap.
BTW serious modifications to that Dana 44 are needed anyway. The knuckles have to be cut off and turned after the SOA, plus the tubes will have to be swapped left to right, so I don't mind if the toy hybrid is not very easy to make. I will just run with whatever idea is cheaper.
