I would start by replacing the broken shaft.so i broke a stock shaft what do you guys say i should do?? its in a toyota 4 runner 4cyl dual cases my front axel is a dana 44 running 37 inch tires. i have 538 gears arb and i want to make this 44 work
x2I recomend putting toy diffs back in it
People have been having really good luck with RCV's up to 38" tires. By the time you upgrade both sides to aftermarket shafts and u-joints, you're almost to the cost of the RCV's...so i broke a stock shaft what do you guys say i should do?? its in a toyota 4 runner 4cyl dual cases my front axel is a dana 44 running 37 inch tires. i have 538 gears arb and i want to make this 44 work
