1 - 3 of 3 Posts
$2500 Dana 60 front kingpin axle originally removed from 1989 f-350
Before you say it, yes I know. The suspension setup is fucked and should never have been done. We were all young once right?
This axle has been upgraded with Reid racing knuckles, cross over high steer with the spring delete.
Yukon chromolly inner and outer shafts
and ctm joints
4.88 gears
It’s setup for a fucked up link setup right now. It needs cut off and something else redone.
$900 Factory discs 14 bolt axle out of a 2005. 4.10 gears. Detroit locker. Setup for leaf springs under a 73 f250. Also has anti wrap bar mounts welded on. In good condition and ready to use in your project
Located sacramento ca
1 - 3 of 3 Posts
