HI. I'm not sure if this is the right forum....built a Dana 60 rear diff. Pattern was good and b/l was 0.007" although I added a thin shim to the opposite ring gear side at the last moment so I don't recall whether the reading was as built or not. It has Motive gears which are known for noise and these are noisy on decel. I took the cover off after about 200 miles. The pattern looks ok maybe a bit towards the OD. B/l is now 0.012". Would you leave it or move shims? I think the pre load was a bit more than suggested using a rubber mallet. I can post some build pics and current pics.
