1 - 6 of 6 Posts
i have been searching for a front 60 for my jeep here recently.
tonight i located two..same guy has them....... he said they have adapters on the hubs to run buddwheels..... said they just unbolt from the original hub and you can put a regular 8 lug wheel on.......
this true?...... is it just like a regular wheel adapter pretty much/?..he said there was a short shaft that needed removed too.... that was used so you could be able to lock the hubs in??:confused:
im cornfused on this one...... can ya'll enlighten me please!
Some axles do have a removable dually adapter. The unit bearing Dodge "Disconnect" Dana 60 is one and the unit bearing Ford Superduty Dana 60 is the other. The 78-97 Ford Dana 60's, 93 and down Dodges, and GM Dana 60's had dually specific bearing hubs.
1 - 6 of 6 Posts
