1 - 2 of 2 Posts
have a 73 chevrolet 3/4 ton that i just lifted and blew the front end up immediately was just a 8 lug 10 bolt so it was forseen but got my hands on a dana 60 front out of a dually, all i could find locally but got a good deal on it for 600$ question is can i get away with just changing the hubs out to a single wheel ? what else may i need to find? talked to a guy that sells the hub conversion kits that includes new rotors and lugs but cant i get away with just doing the hubs? please help much appreciated!!
Vendor
You can use the DRW rotors if you drill the holes out to match the studs you are going to use (with the hole being slightly smaller than the stud to make an interference fit).
Otherwise yes, the difference is just the hub itself.
1 - 2 of 2 Posts
